jetting then exhaust question
    JerseyStepUp
    by JerseyStepUp » Sun Oct 28, 2007 9:34 pm
    If i where to jet my bike with the stock exhaust and snorkel mods... then say a month later decide to get an aftermarket exhaust.. would i need to make adjstments to the carb? if so what would i need to do? im reading alot on this whole jetting thing but still a bit confused
    zak13
    by zak13 » Mon Oct 29, 2007 6:09 am
    when ever you make a change to your bike that would increase/decrease the flow of your intake/exhaust
    you need to rejet yes it is a pain in the rear but thats how life is :lol:
    sellin my xr100
    by [email protected] » Mon Oct 29, 2007 6:49 am
    It is very easy.
    If you already have the re-jetting done with the Honda Power-Up jetting mods ( you should) and the airbox mod you're only looking at maybe backing the fuel screw out a quarter turn,or until it doesn't decel pop. At the most you may want to go up a main jet size, but my buddies didn't require that at all after adding a complete exhaust and after the Power -Up jetting and ran great.
    gte that 15 tooth countershaft sprocket on it too, you'll be glad you did and sorry you waited, just like the re-jetting :D Doug
    zak13
    by zak13 » Mon Oct 29, 2007 7:00 am
    its very easy to do i had no knowledge of caurberators
    so i just went looked at it and started taking it apart and found what i was lookin for and now it runs perfectly
    if youre on a big bike than on the float bowl should be a drain plug un bolt that reach up there with i think an 8mm wrench and a flat screw driver and pull em out put new ones in and re assemble ans youre good
    if youre on a small bike than you have to take the float bowl off
    sellin my xr100
