Air filter
  • DocCRF-X250
    Air filter
    by DocCRF-X250 » Fri Oct 12, 2007 5:03 pm
    What do you like best for your air filter? I have done the air box mod, baffle out, about to rejet and buying fuel screw. I am not sure what to go with for my filter hoping you guys can help? Thanks in advance!!
    BigD
    by BigD » Fri Oct 12, 2007 5:50 pm
    Most go with the Twin Air I think. I have been using the twin air for a couple years and have no complaints.
    No-Toil is a clean and easy way to clean and oil them.
    Also, removing the backfire screen helps the bike breathe a little better.
    2006 CRF 250x
    JD Jet, GPR Stabilizer, Bafflectomy, no backfire screen, 13/51 gearing, oil slick, smoke screen, heat seeking missles, twin 50 cal.'s, etc...
    Re: Air filter
    by JAWS » Fri Oct 12, 2007 5:56 pm
    DocCRF-X250 wrote:What do you like best for your air filter? I have done the air box mod, baffle out, about to rejet and buying fuel screw. I am not sure what to go with for my filter hoping you guys can help? Thanks in advance!!
    If you remove the backfire screen, then go with a Twin Air Powerflo filter. It has a special fire retardant layer just in case you do have a backfire.Using No-Toil is not only easy, as suggested by BigD, but it is not flammable, which is a plus. You can clean your filters in the kitchen sink because it is completely bio-degradable, doesn't have noxious odors, and doesn't leave oily residue to piss anyone off.
    If you don't remove the backfire screen, then you can stay with your stock filter. Personally I like the Twin Air because it has a slightly different profile than the stock one, and that makes putting it in or removing, just a little bit easier.
    by Asmith » Fri Oct 12, 2007 5:56 pm
    BigD wrote:Most go with the Twin Air I think. I have been using the twin air for a couple years and have no complaints.
    +1
    Note: get the Twin Air with flame resistant foam if you pull your backfire screen.
  • DocCRF-X250
    by DocCRF-X250 » Sat Oct 13, 2007 5:12 am
    Where is the best place to get the twin air filter? Do I get a kit for it or is it just replace the stock? Also the backfire screen where exactly is it and how do I remove it? Sorry for the questions guys I know it is all easy and common sense for you guys but I am farely new to doing mods like these! Thanks again in advance!!
    by Asmith » Sat Oct 13, 2007 5:18 am
    DocCRF-X250 wrote:Where is the best place to get the twin air filter? Do I get a kit for it or is it just replace the stock? Also the backfire screen where exactly is it and how do I remove it? Sorry for the questions guys I know it is all easy and common sense for you guys but I am farely new to doing mods like these! Thanks again in advance!!
    Right here:
    http://www.crfsonly.com/catalog/product ... ts_id/1490
    When you remove the stock filter, you will see the foam filter is mounted to a support cage. The cage consists of the metal backfire screen and a white plastic outer cage. Bend the little metal tabs holding the white cage to the backfire screen. Separate the two pieces. The white plastic cage will be reused with your new Twin Air.
  • DocCRF-X250
    by DocCRF-X250 » Sat Oct 13, 2007 5:38 am
    Agentsmith-- with the link you sent can I just buy the replacement filter? I don't need to buy the kit $113.95?Thanks again!!
    by Asmith » Sat Oct 13, 2007 5:44 am
    DocCRF-X250 wrote:Agentsmith-- with the link you sent can I just buy the replacement filter? I don't need to buy the kit $113.95?Thanks again!!
    Yep,
    The whole kit has a pretty gold anodized cage to replace the stock white plastic one. Once you get the filter on the cage and the assy installed and the little door closed, you can't see the pretty cage.
    The white plastic stock one works just fine with the new replacement filter.
    And it's $ 35.00!!
  • DocCRF-X250
    by DocCRF-X250 » Sat Oct 13, 2007 6:19 am
    Thanks a ton ~ I appreciate you taking some time to answer my questions!! Keep up the great job of helping rookies like myself!
