CRF230F Dialed in Jetting
    jtcohenour
    by jtcohenour » Wed Sep 19, 2007 1:05 pm
    I have been racking my brain trying to get my jetting dialed in correctly. The bike pops on decel still. My set-up is as follows:
    132 Main
    48 Pilot
    Needle in Middle Clip Position
    Dr. D Aftermarked Exhaust
    Uni Filter
    Fuel Screw 2 turns out
    gal8x
    by gal8x » Wed Sep 19, 2007 7:55 pm
    you opend the air box? removed the snorkel?
    check for air and exhaust leeks.
    2005 CRF450X (plated)
    by Asmith » Wed Sep 19, 2007 8:30 pm
    gal8x wrote:you opend the air box? removed the snorkel?
    check for air and exhaust leaks.
    Yup and try opening the fuel screw up 1/8 of a turn at a time.
    jtcohenour
    by jtcohenour » Thu Sep 20, 2007 7:22 am
    I sprayed some wd40 around the airbox and didn't notice any increases in rpm. How do I check the exhaust for leaks?
    As for the fuel screw I am hesitant to open it more than two turns as I hear it can fall out?
    by Asmith » Thu Sep 20, 2007 7:45 am
    jtcohenour wrote:I sprayed some wd40 around the airbox and didn't notice any increases in rpm. How do I check the exhaust for leaks?
    Look for signs of exhaust gases escaping. Mix some dish soap and water and put around seal with a small paintbrush, start bike and look for bubbles.
    The Fuel screw will tolerate 2 1/2 turns without issue.
    jtcohenour
    by jtcohenour » Thu Sep 20, 2007 10:12 am
    Once again thanks for the advice. I will let you know how it goes.
    jtcohenour
    by jtcohenour » Thu Sep 20, 2007 4:37 pm
    There appears to be a leak at the header connection to the head. Do you know the torque setting for the nuts that hold the exhaust to the head? I do not want to overtighten.
    gal8x
    by gal8x » Thu Sep 20, 2007 7:43 pm
    jtcohenour wrote:There appears to be a leak at the header connection to the head. Do you know the torque setting for the nuts that hold the exhaust to the head? I do not want to overtighten.
    My book is in the garage but I bet it’s around 15flb.
    Did you replace the gasket when you put your new pipe on? It is a collapsible brass or copper ring.
    It is not uncommon to retighten them after the first few rides.
    jtcohenour
    by jtcohenour » Thu Sep 20, 2007 7:57 pm
    Yes I did replace the gasket when I installed the new pipe. It was a brass ring. I have only ridden the bike maybe 6 times since isntalling the pipe. I just wanted to make sure I wasn't overtightening. 15lbs you say?
