The no-brainer way is the JD kit. It has special needles for altitude. It contains everything you will need, including instructions for altering your airbox to get more air in. Alter the exhaust by either removing 2 rings from your baffle or removing it all together. There is a jetting sticky in the 450X forum at the top. Look that over to see what others are running at your altitude.
The alternative if you want to save a little money and go through your dealer to get jets is:
NCVS Needle 3rd Clip (P/N 16233-men-671)
170 Main
42 Pilot
2 turns out on the fuel screw
Remove Exhaust Baffle
Modify Airbox
http://crfsonly.com/howto/450x/airbox/c ... airbox.php
You can PM Skoot22 or Bocephus450X to get harassed, uh, sorry, to get support for the NCVS setup.
