Elevation / jetting / 06 crf450x
  • JS450X
    by JS450X » Sun Jul 22, 2007 3:20 am
    Well it's been awhile fellas but I'm back with a request for opinions. I got the JD kit awhile back, love it. But it leaves you guessing a bit when it comes to elevation for modified bikes. I have twin air filter (no screen), side vents cut, full T-4 exhaust. Currently running 170 main, red needle 4th position, fuel screw out two turns. This runs good but I am going to ride Ducey-Ershim trail this weekend and the elevations range from 6,000-10,000 ft.
    I checked the JD kit and it says to go with 160 main, 3rd clip position but is this recommendation for stock or modified? I'm also thinking I should probably turn in my fuel screw to 1 3/4 - 1 1/2 turns to keep from being too rich.
    Advice??
    06 CRF450X
    IMS 3.3 tank
    JD jet kit
    jet / air box mods
    Renthal 49 rear sprocket
    Twin-air filter
    Pro-circuit T-4 header/pipe
    by JAWS » Sun Jul 22, 2007 7:12 am
    Your best bet is to call JD and ask hin. He will be happy to help you out.
