Help!! Bog and Jetting concerns for 07' CRF250R
  • Darkbox
    by Darkbox » Fri Jul 13, 2007 6:38 am
    The bike is bogging especially when landing off jumps and getting back on the gas hard again. I've read about the Boyesen Quickshot, the Powernow, JD Jetting kit. I'm not sure what to do to cure this problem. My bike is 100% stock. I have spoken to the local Honda shop tech guy and he said on his own 07' CRF250R he's tried a number of jetting changes and none have cured the problem. Any recommendations would be greatly appreciated.
    Thanks,
    Russ
  • TDW
    by TDW » Sun Jul 15, 2007 8:51 pm
    Sorry, I dont know much about the problems 07's are having, apparently nobody else does either?
  • Wantabe
    by Wantabe » Sun Jul 15, 2007 11:42 pm
    I have 2-2006 CRF250R. Same problem as you describe. On one of the bikes I placed the Boyesen Quickshot II, JD Jetting kit, CRF only fuel screw and completed the accelerator mod. The problem was solved!! On the second bike I did the same thing except did not place the Boyesen Quickshot II (saved $100). Again problem solved. I'm very happy I made the changes
  • BREW
    by BREW » Mon Jul 16, 2007 11:28 am
    I had the same problem with the '06. White Bros. carb kit fixed everything
