Optimum Exhaust Gas Temperature
  • americano
    by americano » Wed May 02, 2007 3:23 pm
    Does anyone know what the optimal Exhaust Gas Temperature is for an '02 (EGT sensor is 6" from center of cyl)?
  • loff
    by loff » Fri May 04, 2007 10:15 am
    How about getting the bike warmed up and then adjust the fuel screw to rich of peak EGT.
    Where did you get the EGT gauge?
  • americano
    EGT
    by americano » Mon May 07, 2007 7:54 am
    EGT is mychron (AIM). the engine is in a superkart and there is not a screw since it is jetted. On 2-cycle, you develop the peak EGT under a load at the end of a straight and cannot develop the same EGT without a load....is this different for 4-stroke?
  • loff
    by loff » Mon May 07, 2007 9:36 am
    My experience with an EGT gauge is from flying small airplanes.
    If you have a carburetor you should have either a fuel screw or an air screw. Otherwise you could not make small adjustments to account for temperature, elevation and humidity.
  • americano
    screws
    by americano » Mon May 07, 2007 10:04 am
    yeah, there are adjustment screws for idle stop and idle mixture, but the mains are fixed jets on my engine. On my 250 and my 125, I have adjustments (on the 125, it comes from IAME with a hand adjustable needle, and on my 250, I have a dail that I can turn while I am racing.
