Stumped crf250r 2k5 8000'
  • badkittypaintball
    by badkittypaintball » Sun Apr 01, 2007 10:04 pm
    ok i installed a 170 main jet took the clip on the needle to the 2nd pos and i adjusted my pilot to 1 3/4 no my issue is when the choke is on it runs like normal low idle speed. if i have it choked and pull the hot start it runs like it normally should with the choke on higher idle speed. if i close the choke its dies unless i give it gas. at 1/4 to full throttle it runs like it should it just wont idle or stay idling what is my next step i played with the pilot full range and i needing a smaller slow jet or bigger or some kind of air jet im not gettin or what
    i brought the bike from tx and now live in colorado and also has a t- full exhaust im just at a loss on what i should do
    by Asmith » Sun Apr 01, 2007 10:11 pm
    Your pilot (slow) jet is clogged. Remove and clean thoroughly.
  • badkittypaintball
    by badkittypaintball » Mon Apr 02, 2007 12:27 pm
    no its not clogged none of the jets are clogged at all no passageways are blocked everything is all nice and clean
