adelanto carb problem
  • rfcgmb
    by rfcgmb » Mon Feb 26, 2007 1:55 pm
    my 04 crf450 had major problems.
    first I could only start it with the choke on
    second if I turned the choke off the bike would stall out
    i messed with the idle it made the rpms higher but sounded to high.
    My setting were 168 42 1 1/4 on f/L screw
    stock pipe boysen ac pump cover
    please help me out
    by Asmith » Mon Feb 26, 2007 1:58 pm
    Pilot jet clogged.
    Also, sounds poorly jetted for an R. Those numbers are actually small for an X.
  • rfcgmb
    by rfcgmb » Mon Feb 26, 2007 4:28 pm
    when I was at the race a buddy and I cleaned the card out and the jet. I just got back from cms and bought a 165 jet i will install that and see if that corrects the problem.
    by Asmith » Mon Feb 26, 2007 4:56 pm
    rfcgmb wrote:when I was at the race a buddy and I cleaned the card out and the jet. I just got back from cms and bought a 165 jet i will install that and see if that corrects the problem.
    Did you take out the pilot to clean it? Can't be cleaned by shooting carb cleaner at it. Must be removed and hit with cleaner and compressed air.
    The 165 is the main and it isn't even operating until at least 1/2 throttle.
    That's the main, not the pilot. The pilot is the 42 and should probably be a 45.
  • rfcgmb
    by rfcgmb » Mon Feb 26, 2007 7:30 pm
    yes i did clean out the pilot jet. i will install a 45 tomorrow. anything else
    by Asmith » Mon Feb 26, 2007 7:41 pm
    rfcgmb wrote:yes i did clean out the pilot jet. i will install a 45 tomorrow. anything else
    That ought to get the bike running.
    For more optimal performance you might consider a JD jetting kit. If you just want to mess around with your own jets, I would think that the main should be somewhere around a 180 for a 450R. The needle should be on the 3rd or 4th clip. 45 pilot and the fuel screw at 1 1/4 turns is a good place to start. The fuel screw will probably need some adjusting out from there to eliminate decel pop and/or bogging.
    Good luck.
  • rfcgmb
    by rfcgmb » Tue Feb 27, 2007 8:24 am
    why would a 180 main be a good idea i don't understand. can you explain. thanks, all this info is a blessing.
