lvcrf250x wrote:What should i jet to?
i ride from 2000-3500 ft
i got the boyseen AP cover
WB fuel screw
UNI air filter
Baffle removed from air box
and am getting a CHM full exhaust
no CCC mods other than pink wire
Thanks in advanced
Halen wrote:Once you answer Agent's questions, he is going to tell you to go with the JD jet kit, red needle in the fifth position, 162 main and then go purchase a 42 pilot from honda...![]()
In my humble opinion just removing the baffle does not allow enough air flow to really make the difference you are looking for. I cut the airbox but left the outer 'rails' intact so if I ever want to replace the baffle I can just glue it back in. It is quite amazing the difference that the X and the R have concerning the airbox. The X is almost closed in comparison. And it seems, all us Xer's, are just trying to get the power handed out by the R.
I was hesitant at first to do all these carb mods but after some fine convincing they all worked out great!
hope this helps... later
Van
lvcrf250x wrote:The people at honda said that it was way to rich to run the 162. Should i listen to them?
What comes in the JD jet kit?
~ wrote:lvcrf250x wrote:The people at honda said that it was way to rich to run the 162. Should i listen to them?
The CRF 250X kit contains the Small o-ring, Large O-ring, Red Tipped Needle, Blue Tipped Needle, 150, 155, 158, and 162 Keihin Main Jets.
You can listen to the dealer if you want to, but they are the ones who sold you a lean bike to begin with.
It doesn't matter to us what you run. Our bikes won't run any differently if you run stock jetting. We know what works and what doesn't.
Stick with your stock jetting and have fun...or listen to us and get your bike running the way it should.
NCLR1 wrote:fatty432 wrote:
Hey A.S.
I'm at 2800 ft. and ride between 2800 and 8000 should i stay with the 42 main, I need to go get one for this weekend.
Jeff
Sorry for dippin in but, are you saying that you have a 42 main or pilot?
