Jetting 2007 250X
  • ibiro
    Jetting 2007 250X
    by ibiro » Mon Jan 01, 2007 1:34 am
    Hello All
    My 2007 250x is a European spec. No air pump and no Anti smog kit. Haven't done a physical check, but my owners manual says:
    Main#132
    Needle pos: 3rd groove from top
    Slow jet#42
    Pilot screw: 1 7/8 turns out.
    Anyone taken air pump and smog kit off their bikes, got jetting specs. I'm running at about 1000 to 1700`
    None of the jetting posts can help me so far.
    Modifications: Drilled the baffle with 11/16 hole
  • joegencon
    by joegencon » Wed Jan 10, 2007 7:27 pm
    Get the JD Jetting kit available on this site. Worth every penny. The stock specs make the bike like a clogged up lawnmower. Use the kit and you will be amazed.
    "06" CRF250X Me
    "07" CRF150RB Nick
    "05"CRF100F Christy
    "04"CRF 70F Jason
    KevinM
    by KevinM » Thu Jan 11, 2007 9:27 am
    ibiro.. my 250X is pretty much like yours. No smog kit. It's a 49 state model. Not California model. See my post above.
    Other than altitude, our bikes are pretty close. But you're at a slightly higher altitude than I am.
    Get the JD Kit. But use a smaller main then me. #152 I think or something close.
    Use the red JD needle at the 4th clip position. Your pilot circuit looks OK. Make sure 1-7/8 works best. I'd think maybe slightly less turns out since 1-7/8 works for me at sea level with a 42 and a wide open airbox.
    If you can't get the JD kit, try the NCYS needle. Try 4th clip position.
    And get a 152 main. 162 like I'm using is too big for a closed up airbox. Your 132 is too lean. Especially since you drilled the baffle.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
  • ibiro
    by ibiro » Mon Jan 15, 2007 11:57 am
    Thanks for the input, I'll give it a try.
