Jetting database for Honda CRF's
    devistation
    by devistation » Fri Dec 09, 2005 5:13 pm
    J\D kit 170 main\#45 Pilot
    Red needle 4th clip
    Side vent's cut, Top of airbox cut
    Crf's only fuel screw @ 1 1\2
    Twin air filter, stock cage with backfire screen removed
    Applied smog block off kit
    Applied cc vent
    FMF Titanium PowerCore
    Ride @ sea level - 5000 ft mostly
    Nice tan plug!!!!
  • Scott Wilson
    by Scott Wilson » Tue Dec 20, 2005 6:42 pm
    I asked the question about jetting on the 05 250R I just bought them for my kids and I dont want them to be too lean. any suggestions? Thanks
  • Scott Wilson
    by Scott Wilson » Tue Dec 20, 2005 6:44 pm
    Oops we ride in Ocatillo wells most of the time. Regarding the jetting I am not sure of the alt, there
  • Scotter
    by Scotter » Sat Dec 31, 2005 4:07 pm
    Mustang,
    Just finished the mods to my 450X. $4.50 170 main jet, Applied Breather Removel Kit $19 (could have made it for $3 plus the breather), White Bros Smog Removel Kit (could have made for $5), Removed the pipe insert (flows free know).
    1000'
    170 main jet
    1 1/8 fuel scew
    Top of air box cut out only
    stock filter
    pipe insert removed
    White Bros block off kit
    Appiled breather removel kit
    4th position on needle
    no pink wire yet
    Bike fired right up and idled perfect. Let it warm up turned the chock off and went burning down the street. Could have done it a little cheaper without the removel kits, but it was not that expensive.
    Scott 8)
  • honda_rules_2005
    by honda_rules_2005 » Sat Dec 31, 2005 6:12 pm
    Got a 05 CRF450R
    #170 main
    #42 pilot
    Needle clip in 5th pos
    07 CRF450X
    Pro cercuit T-4 system.
    JD jetting kit,
    Hotcams stage 2 cam,
    CP 13:01 piston,
    Head modified with oversized Billet titanium CRN couted valves allround, ampco45 copper seats and guids with spring set.& also heavilly ported.
    RottenRob
    by RottenRob » Fri Mar 10, 2006 10:33 am
    Red JD needle middle clip position
    170 main
    Stock Pilot
    1 1/4 out on Fuel Screw
    Yosh Carbon Fiber slip-on
    1/4" holes drilled in side panel slots/vents
    Smog and Crankase block off kits
    Pink Wire
    Life's tough, but it is even tougher when you're stupid.
    by [email protected] » Sat Mar 18, 2006 1:33 am
    O5 450X
    OK, let's go front to rear :
    A beautiful,but invisible red front axle nut.
    Flatland odo spacer
    Red Excel wheels
    Race Tech revalve and springs
    Fastway front brake line guide
    Red Applied triple clamps
    Gold Pro Tapers.
    AceWell 3100 speedo
    Cycra ProBends
    Works Elite clutch perch
    Rekluse external clutch clutch perch
    IMS 3.2
    Project 321 gas cap
    Red Unabiker radiator guards
    Red Works Connection skid plate
    ZipTy petcock
    ZipTy Hot Start nut
    Works red engine plugs
    Red SFC clutch cover
    FastWay CS guard
    HammerHead shifter tip,red
    Rekluse automatic clutch
    HotCams Stage 2 camshaft
    JD jet kit 165 main in space no.# 5 ,45 pilot , Boyeson QuickShot, 2 turns out on fuel screw.
    Top and sides airbox open
    TwinAir PowerFlow
    Applied Crankcase breather kit
    IMS footpegs
    Works resevoir caps,red
    TM Designworks chain guide system ,red
    ZipTy axle blocks,red
    ZipTy red axle spacers
    Pink wire mod
    Yoshimura TRC strap on
    Red Renthal rear sprocket
    Thats all for now,I think....Wait'll next year when it needs a top-end ! No, it won't be a big bore kit . Doug
    PhatFireMan
    by PhatFireMan » Sat Mar 18, 2006 4:44 pm
    '05 CRF450x
    1500'-3000'
    JD Red #4 Clip
    170 Main
    48 Pilot
    Applied Fuel Screw 1.5 Turns
    Boyesen Accelerator Pump Cover
    Twin Air PowerFlow Kit
    Airbox Sides Cut-Out, Snorkel Removed, Top Cut-Out
    BigGun Evo-X Slip-On, Spark Arrestor, No Sound Baffle
    Applied Air Injector Kit
    Applied Crankcase Breather Kit
    IMS 3.2 Gallon, Black, Shorty Vent Hose
    Napalm Filter Screw
    GPR V3 Steering Damper, Sub-Mount, Remote
    Forks Raised 1/4"
    TAG CR-Bend Bars
    STR Speed Bleed Buttons
    ASV F3 Levers/Perch
    Garmin GPS
    Scott's Rear Disc Guard
    Flatland Front Disc Guard
    Works Connection Rear Caliper Guard
    Works Connection Skid Plate
    Works Connection Radiator Braces
    5-10 Case Saver
    Tag 49 Tooth Rear Sprocket
    Zip-Ty Magnetic Float Bowl Plug
    Foot Pegs RAZOR sharp
    91 Octane Pump Gas
    AMSOIL 10w-40 Sythetic
    Full Quart In The TRANNY! :!:
    Image I absolutely LOVE this bike!
    Ravage
    by Ravage » Wed Mar 22, 2006 5:25 pm
    04' CRF250X
    1000-1500ft
    55-75
    Red JD needel in 4th pos
    165 main
    Stock pilot
    Modded air box
    Twinair powerflow kit
    Zip-ty fuel screw
    Dr. D full system(with quiet core)
    Hotcams stg 1
    Applied crankcase vent kit
    Renthal fatbars
    Applied bar mounts
    Flatland rad guards
    Trail tech computer
    "250R" rear fender
    "250R" front number plate
    Throttle jockey woody graphics
    FX seat cover
    06 RM250
    04 CRF250X #724- SOLD
    03 XR250
    74 CB350
    Eric Mac
    by Eric Mac » Mon Apr 03, 2006 8:31 pm
    2000' +-
    162 main jet
    stock clip fourth position
    stock setting on fuel screw
    Air box snorkle removed
    Applied vent kit
    Stock air filter
    Moose handguards
    Devol skid plate
    Devol radiator guards
    Rekluse clutch cover
    Question:Obviously the bike woke up when I gave it some gas and air, but I dont know if it is still lean or if it needs more air. Should I just get the JD jet kit and Twin Air and be done with it, or should I leave well enough alone?
    $1500 worth of mods to realize I cant buy skill!
    BigOL3
    by BigOL3 » Thu Apr 06, 2006 8:04 pm
    see below
    sea level-1000'
    Utah skidplate
    Unabiker red rad guards
    CRF's Only rear tugger
    CRF's Only FS
    JD jetting kit..170 main, red neddle, 4th pos
    Twin Air Power Flow kit w/Napalm mounting bolt
    Air box snorkle remvd... Exhaust baffle remvd
  • ruberban
    by ruberban » Tue May 02, 2006 7:51 am
    Jetting data base for crf's
    Model: CRF450X
    Altitude: 0-3000 ft ASL
    Pilot jet size: 42 (Stock 45)
    Main jet size: 165 (Stock 142)
    Leak jet size: 65 (Stock 70)
    Needle used: JD Red
    Clip location: 5th from top (The kit Recommended 4th)
    Airbox mods: Top open, rubber piece removed under seat, (not cut anywhere = Stays cleaner, longer)
    Air Filter changes: Twin Air Filter element
    Other related changes: Removed backfire screen.
    DR D Header and Pipe. SRC Fuel Screw 1-1/2 Turns out from seated. Boysen Quickshot. Accel Pump Timing set to .120 (Stock .100)
    I had a terrible bog and off idle hesitation problem before the above work. It almost caused me to drop the front end into a washout the first time I rode it. A change had to be made for safety and performance.
    Currently: Bike revs extremely quick. Zero bog/hesitation. You can blip the throttle as fast as you like and it responds immediately. Low to mid range power is awsome. This bike ran like a POS in stock form. This bike may not get enough credit if you just check it out from the showroom floor. Until you experience a properly tuned bike, with minimal mods you can't appreciate it. I know the quickshot, exhaust, an air filter and jets aren't cheap, but the results are unbelievable.
    Hope this helps..
    Ride hard,
    Stay Safe,
    Regards
    Ruberban
  • Primative
    CRF250X
    by Primative » Wed May 10, 2006 9:40 am
    My jetting for 2004 CRF250X
    155 main
    42 pilot
    2.5 turns air screw
    Stock needle in 4th position
    Snorkel removed, box cut per Honda spec
    Baffel removed
    Runs very well at sea level to 1,500'
    I tried stock mains (130) to 140, 145, 150, and finally settled on the 155. it runs a little rich with this set up, but I can solve that be getting a CRF450X needle and putting it back in position #3. would be all I need to do to fine tune things.
    "If you tell the truth, you don't have to remember anything."
  • Darinrd
    jetting data
    by Darinrd » Wed Sep 13, 2006 9:30 pm
    06 450X - sea level to 1000 ft.
    JD jet kit, red needle, clip in 4th position
    170 main
    stock pilot
    Air box opened on top and sides
    Twin air kit
    Stock exhaust (plug removed)
    Darin
    mdmasher
    My set up.
    by mdmasher » Fri Sep 29, 2006 10:46 pm
    Main 162
    Leak #50 aka ACC pump bypass
    Needle stock clip #5
    Air box top removed only.
    Stock air filter.
    Stock pipe.
    Pink wire stock
    Air screw at 1-5/8 to 1-7/8 (200 to 5800 ft)
    Smog, stock for now. will plug soon. CA. thing.
    all mods directly from dealer. on paper.
    New CHM pipe. No change to Jetting per dealer.
    After market stuff.
    Works skid plate.
    Works radiator brace
    Fork air valve
    Hand guards
    Clarke 3.4 tank.
    Flag mount. home made.
    Extra 18" excel rear wheel. Paddle 8
    Extra O ring chain 117 link for paddle.
    Best toy on my play ground.
