Usually when a Dealer gets a trade in , they may adjust the valves , or take the prior owners word that it runs good , and just wash it , fire it up , and if it runs , then they just re-sell the bike , but if the valves are toast , you can literally adjust them , and within a couple hours they will be closed up again , that is the sign of needing valves ... basically when you need to start adjusting them period , then they are closing up and will eventually (it varies greatly) close up and you will run out of shim sizes ... once you get to needing a 1.20 shim , you are done and there is no adjustment left , so depending on what actual shim is in there , is going to tell you where you are at , but anything under 2.0 is bad news , so once the valves start to move and are in need of adjusting , it is only a matter of time before they are done , so you need to prepare for either replacing the valves and have someone cut the seats , or have a shop do it (someone that does these bikes not just a regular automotive shop , as they don't have the correct tools , nor know how far you can cut the seats before you ruin the head)
The way these valve systems are designed , the stem sticking out is what determines the shim needed under the bucket or at the rocker , once the valve face wears , it goes deeper into the seat and wears the seat in the head as well as the valve face , so what happens is the stem will now stick out farther , and there is less room for a shim , till you get to the 1.20 , then no more shims are available and your valve lash is at zero , which means the valve will slightly hang open and you will not be able to start it without compression , but the valve being worn prevents that ... plus the fact the valve face is now becoming so thin , that it can literally snap off and suck the valve , which then hits the piston and/or cylinder wall , then you have a whole new set of issues and things to replace ...
So yea , usually dealers just flip them and don't spend much time , if any , on maintenance , as that takes away from the profit margin ....
You can download a Owners Manual direct from Honda , as that would be much better than the Clymer one , the Clymer manuals are kind of generic and don't have the stuff that even the Owners Manual has , or better yet , if you plan on keeping the bike for a while , get a Factory Service Manual , they are about $60.00 (you can get one here)
https://www.crfsonly.com/catalog/produc ... ts_id/3226 , as it will cover the entire electrical system , engine , suspension and anything else that can possibly go wrong with the bike ,,, but the Owners Manual will cover the valves , rebuilds , and suspension as well ...
Link to Honda Owners Manual PDF download : Just click on
Year 2016,
Segment/Off Road ,
Category / Trail ,
Model /450X , then download the manual and you have it on your PC and/or Phone all the time for reference
https://powersports.honda.com/downloads/owners-manuals
