2016 CRF250L - wired through the ignition
    Lemonsieur
    by Lemonsieur » Wed Jan 13, 2021 6:36 am
    Hi everyone,
    I have bought a 2016's CRF250L and I would like to plug my Oxford Hot grips and a USB charger but I don't know where to start...
    People told me to wired through the ignition, so my battery will not depleted when I will forgot to switch them off.
    I'm totally noob in this field, my knowledge is close to void, and as far as I know, it's more complicated to do those things on models before 2017.
    Which are the best/simple/efficient ways ?
    Thanks a lot and happy new year !
    Re: 2016 CRF250L - wired through the ignition
    by Back2-2 » Wed Jan 13, 2021 2:14 pm
    To be quite frank & honest and no intention to offend you - If you are not familiar with doing electrical work I suggest you look for someone else to do the wiring for you.
    They are correct it telling you to use a power source from the ignition and for the reasons you stated. It will need hot source that is live only when the ignition contacts are active and off when it is not. Which wire for the source would require a electrical schematic to find the best wire to be used. Also a good ground lead. Things that have to be taken into consideration is that the source is fused and that you will not overload the wire with the additional amp load. Other things to consider is that your stock electrical system can handle the addition amp loads.
    Maybe that gave you a little insight to what is required.
    Lemonsieur
    by Lemonsieur » Thu Jan 14, 2021 5:08 am
    Well, I'm willing to learn and try, more I will absorb knowledge, better will be my overall understanding.
    I'm planning to travel around Eurasia this year for at least a year (if Covid will permit it) with a friend who got himself a 2017 Rally, so we are starting learning basics mechanics to be able to repair on route.
    I am aware about the fuse and the amp loads, and I read many ideas to my problem (like installing a relay or the black/orange horn feed and a double connector...), but I was wondering if someone could guide me precisely, like a tutorial on the most efficient solution.
    I can have someone who can do that for me, but I want to learn by myself as much as I can by doing or at least trying, for my understanding and to not waste other people time :)
    Thanks for the advices.
    by Back2-2 » Thu Jan 14, 2021 9:45 am
    I suggest you find a wiring diagram and go from there. If you do not know how to solder properly then you will need to use crimp connections where fine if done properly. Pretty straight forward. Find a good fused hot lead that can handle the load and splice into in for the supply. The ground can be any good source of solid ground connection. That is assuming that you have a electrical output of the bikes system to be sufficient and that the heated grips have their own off/on switch.
    Good luck on the project. It really is one of the easier electrical mod's. Disconnect the battery leads before doing any work.
