by RiskMan » Thu Sep 04, 2008 11:01 am
I appreciate your reply. Thought I'd provide an update...After pulling the spark plug, I stood the bike up so the exhaust opening was pointed toward the ground. (Lots of water and mud drained out.) I wound up removing the silencer so I could get all the mud out. Then I moved on to the airbox. It had almost two inches of mud / silt in the bottom. I completely removed the airbox, including the connection to the carburetor, and thoroughly cleaned all parts. Next, I stood the bike up again and opened the throttle. Mud and dirty water drained from the carburetor and from the hose that runs from the airbox to the engine, near the oil dipstick. That's as far as I've gotten so far. I'll remove the carb float bowl next and clean it out. Based on the amount of water and mud I've found, I'm pretty sure there's more in the engine oil. At this point, I'm wondering if I need to pull off the cylinder head to make sure there's no mud in there...?
