450x street legal
  • olddude
    450x street legal
    by olddude » Mon Jul 30, 2007 2:11 pm
    450x Street legal Kits: Anyone recommend a certain kit or should I just engineer a few things myself? Any suggestions?
    djh65
    by djh65 » Mon Jul 30, 2007 7:01 pm
    Depends on what state your in from past posts it ranges from NO (CA.)to a flash light duct taped to the bars.
    David
    06 HD450X made in america.
  • gobigohome
    by gobigohome » Wed Aug 01, 2007 12:31 am
    i put a brake light switch in by the bleeder valve a clown horn and a mirror cost me about 30 bucks and it has worked twice i got it vin checked in cleveland ohio and then had to get it rechecked in vail colorado worked great
    mikey v
    by mikey v » Sun Aug 05, 2007 5:52 pm
    Here, in Ohio, you are supposed to have a headlamp, tailamp, brake lamp, turn signals, horn, and rear view mirror. The truth is, if you have a working headlamp and tailamp, and a rearview mirror, most law enforcement will leave you alone. The exception to this rule would be if you got stopped by the Ohio State Patrol. They are sticklers for equipment function. The good news is that we rarely encounter troopers in the remote areas we ride.
    I used a CRF450X headlamp, and an Acerbis tailamp/fender extension, a clown horn, and a bicycle mirror. There is a ton of lighting on Ebay. Lots of cool little LED turnsigs, and tailamps.
    2005 CRF450X
    07 HD Street-Glide
    kicken
    by kicken » Mon Aug 20, 2007 5:48 am
    Just import one from Australia ... they're street modded (ADR) to the crap when you buy them from the dealer ... including a new master cylinder with brake light switch and mirror mount, modified cluch perch for mirror mount and longer levers, rear brake master cylinder switch for brake light, xr-style switch block for horn attached blinkers and newly fitted head light with high/low beam and larger lense, street legal tyres, new rear rego plat holder with larger rear tail/brake light, then a keyed ignition and seperate switch on/off block (as apposed to the kill switch) ... then they throw all the jap/us stuff they strip off the bike into a box and give it to you as spares !!!
    So then the aussies spend three days removing all the crap to bring it back as clost to stock as possible and lost 10kg of weight :roll:
    '06 CRF450x
    Jethro
    by Jethro » Mon Aug 20, 2007 8:44 am
    baja designs makes a kit that comes with close to everything for under $500. my friend put it on his bike like 6 months ago. let me know if you need to know anymore and i will try to find a pic and what the kit was called
    djh65
    by djh65 » Mon Aug 20, 2007 9:01 am
    I got mine street legal. It was pretty easy all I had to do was sign my name. lol
    David
