This is the basic steps for valvetrain replacement. There may be specific items for the different displacements and/or models. The write-up and pics in this post are from a 2005 CRF450R.
Some parts of the process described below assume that your replacing the valvetrain, not checking the clearances or shimming. The steps taken for either of the aforementioned may vary from below. The process below also assumes you know that clockwise tightens things, you can read specifications, and that hot things hurt when you touch them.
1) Clean the bike thoroughly. Especially the airbox, engine, carb, and under the tank. Ruin your valvetrain because of a dirty intake; shame on you. Ruin your valvetrain again because of a dirty intake after rebuilding it; shoot yourself.
2) Disassemble the bike and get it ready for engine teardown. Drain the coolant. Set the engine at TDC of the compression stroke.
3) Remove the valve cover.
4) Remove or release tension from the timing chain tensioner. Remove the cam gear, secure the chain, and remove the camholder asm. Cover the cam chain cavity. BECAREFUL - the shims will be stuck to the underside of the buckets. They may fall out when lifting the cam holder. Fishing them out after they've fallen down the cam chain cavity isn't fun.
5) Loosen the fasteners holding the head on in a criss-cross pattern a little at a time until all are loose. Remove fasteners. Carefully pull the head off.
Bottom of the head:
Top of the piston:
6) You should have received your new valves and spring kit by now. And the piston kit if you plan on replacing it. Recognize that these thumpers are much more durable regarding cylinder/piston maintenance. You can typically get away with just doing the rings at this point if there isn't a ton of hours on the bike. With that said, I always do a piston kit when replacing the valvetrain. If you are also replacing the piston, remove the cylinder.
7) Remove the old piston and install the new one. Pay attention to the direction of the piston. In "the old days", 2-stroke pistons had an arrow that faced forward. 4-strokes, typically the arrow or indicator faces rearward, or toward the intake. But, always read the instructions included with the piston kit you have to clarify. Also, a quick way on our bikes is to notice that the intake valves are larger than the exhausts, and the "pocket" in the piston accomodate for it.
8 ) Inspect the cylinder. The CRF "R"s and "X"s have a nikasil plated cylinder. It is approximately a 2-5 thousands of an inch thick alloy (nickel-silicon) plating that assists the cylinder in improved durability and cooling characteristics. You should not hone these cylinders. With that said, if you do, be very careful not to take too much material. It is possible to hone through the nikasil. My cylinder had good cross-hatching and only showed one area where it was slightly scuffed. After careful review and measurement, no action is needed.
A quick way to determine if a scratch is indeed a scratch; is the fingernail method. If you can catch it with your fingernail, it needs to be fixed. Millenium technologies does very good cylinder plating work.
9) Clean the gasket surfaces thoroughly. Coat the cylinder and new piston with clean oil. Install cylinder.
A note about the valves: The reason behind the valve issue is related to the coating on the titanium. The coating on the valve where it meets the guide wears just enough that the valve starts to wobble in the seat. Once this starts, it is a deteriorating process and gets worse over time. The reason why stainless and other materials are more durable, is because of the different coating processes and/or the lack of a coating. Why use titanium then? I think it is to save weight. The valve parts:
10) The headwork was done professionally. They removed my old valves, replaced the seals, repaired the valve seats, and installed the new Kibblewhite stainless steel valves and springs. My intakes definitely needed repair while the exhausts were cleaned up to remove some pitting. The new valves installed.
11) Install the new gasket and the head. Torque to spec in a criss-cross pattern.
12) Now, because the valve seats have been grinded, the shims that came in the bike from the factory will not work. There will be a small amount of adjustment lost because the valve sits deeper in the head. There will be some guesswork involved on what shim size to start with, unless you recorded the shim sizes the first time you shimmed the bike. In which case put in the original sized shims. Then check the clearance, make the calculations, and install the necessary shims to get you back to spec. Re-install the cam holder, and torque to spec in a criss-cross pattern.
Verify the piston is at TDC. Line up the cam gear with the mark on the case. Make sure the cam lobes are facing rearward and install the cam chain. Maintain the exact line-up of the piston TDC, the cam gear lined up with the mark on the case, and install the bolts. Tighten the fasteners to spec. Install and set the cam chain tensioner to the proper tension and re-check that the timing is correct. Set the decompression clearance and turn the engine over a couple times. Re-check the timing and valve clearance again. Re-adjust if necessary.
13) Put the valve cover back on, fill the bike up with fluids, and complete the re-assembly. Done!!
