How to adjust front headlight
Posted: Thu Feb 22, 2007 10:01 pm
by aleaayala
Hello, can anyone tell me how to adjust my front headlight on my stock CRF 250 X 2004 its a little high and I cant get it to go lower.
Thank You
yes look in your manual
Posted: Fri Feb 23, 2007 10:51 am
by woodsman
it should tell you in there biut I suggets that you get a bigger one from Baja Designs.
Posted: Fri Feb 23, 2007 12:28 pm
by Kingby
Should be a single screw at the bottom of the light that adjusts the angle up an down. The light is attached as a hinge on top and a screw adjusts the bottom attachment in and out (there by changing the angle of the beam up and down). Your manual has very good instructions on this.
Mike
Posted: Fri Feb 23, 2007 1:21 pm
by aleaayala
Thanks, thats what I needed to know because I was trying the screws on the back of the headlight, the problem is I cant find my manual.
Thanks
Posted: Sat Feb 24, 2007 7:47 am
by Halen
Single screw at the bottom of the light
clockwise to raise the beam
counter-clockwise to lower
The two at the top of the light just act as pivots
Van
