How to adjust front headlight
  • aleaayala
    by aleaayala » Thu Feb 22, 2007 10:01 pm
    Hello, can anyone tell me how to adjust my front headlight on my stock CRF 250 X 2004 its a little high and I cant get it to go lower.
    Thank You
    woodsman
    yes look in your manual
    by woodsman » Fri Feb 23, 2007 10:51 am
    it should tell you in there biut I suggets that you get a bigger one from Baja Designs.
    Kingby
    by Kingby » Fri Feb 23, 2007 12:28 pm
    Should be a single screw at the bottom of the light that adjusts the angle up an down. The light is attached as a hinge on top and a screw adjusts the bottom attachment in and out (there by changing the angle of the beam up and down). Your manual has very good instructions on this.
    Mike
    2005 CRF450X (Pro Tapers CR-Hi bend, 15mm bar risers)
    2003 Toyota Tacoma 4x4 to haul it in
  • aleaayala
    by aleaayala » Fri Feb 23, 2007 1:21 pm
    Thanks, thats what I needed to know because I was trying the screws on the back of the headlight, the problem is I cant find my manual.
    Thanks
  • Halen
    by Halen » Sat Feb 24, 2007 7:47 am
    Single screw at the bottom of the light
    clockwise to raise the beam
    counter-clockwise to lower
    The two at the top of the light just act as pivots
    Van
    09 CRF 250R
    RMR lowered suspension
    Heavily armoured for the bush
    50 tooth rear
    soft gel seat
