by madmax » Fri Feb 02, 2007 10:53 am
You can, this is how you do it on the 250s. But i think it`s a WHOLE lot easyer to put the cam in, and put the chain on the gear. You can line up the gear and move the cam with your fingers till the bolt holes line up.
Just remember to always have the lobes facing rearward or better, pointing straight up when putting the cam on. If they are hitting the buckets and you tighten the bolts it will push the valves into the piston and maybe bend one.
03 450R
02 GXSR1000
05 250X (kid #1)
05 250X (kid#2)
