Welcome to the site !!
About the only thing you could do is try getting a set for a CRF150R and trying to adapt the stem to fit the size of yours (length of stem and bearing O.D.) , and have the length of the tubes ( you can install limiters) so the overall length is the same as your bike stock to keep the geometry and balance of the bike the same and safe ... Emig Racing (Jeff Emig the retired MX'er/Announcer) sells a kit for the CRF230 , but not sure if it will adapt or work with the 125F
http://www.emigracing.com/crf230f-crf250450f.html , but its not cut and dried , like bolting the kit on and going , there is a lot of other things to consider , maybe look into that and decide if it is worth the effort , or to just buy a CRF150R or similar ... and be done with it .... , unfortunately , the F bikes are basic and don't have the options of the other bikes to keep costs down , like inverted forks , the conventional forks are much cheaper to manufacture , maybe Ray can chime in with something he may know , as he is the small bike Guru around here .... , but I am thinking you may end up going the route of the 150R
