Welcome to the site !!
Are you talking about one of the 8 bolts that hold the fork in the triple clamps ?? , if so and it did not snap off , then if it is just the head rounded , then you can try lubricating the bolt in between the pinch points so it gets penitrent on the threads ,what I would use if you have access to it (I know with everything being closed because of the virus , it might be difficult to find a hardware store open , but if you can) , is get some Acetone and some ATF (Automatic Transmission Fluid for a car *the cheap stuff will work fine* , you can find the Acetone in the paint dept.) , mix it 1-1 and pour it as close to on the threads as you can , so it can soak in , ...... if you can't get those 2 items then something like PB Blaster , if you don't have any of that , then WD-40 or Liquid Wrench will still work , but might take longer , let it soak as long as you can , overnight if possible , but even 15 or 20 minutes will help ,
Then use a flat vice grip pliers on the bolt head to hold it , you want the flat ones as opposed to the rounded one , so it grips solid and flush on the flat part of the bolt head to give you the best bite ....... clamp it down tight , so you have to force the handle closed , then while holding it with one hand , use a hammer (preferably heavy like a brass hammer or a small 1 lbs hand held sledge hammer) , and hit the vice grip right at the bolt head , while trying to loosen it , you don't need to beat it , just let the weight of the hammer do the work , what the hammer will do is shock any buildup that might be keeping the bolt from breaking loose easily , which is most likely why it was stuck , as steel bolts and Aluminum corrode when in contact with moisture or high humidity , and the bolt can corrode itself to the threads ...... like yours has .....
Once you get the bolt out , and get a replacement (always use a shouldered bolt on the clamps) , then get some Anti-Seize and put it on the threads of all the bolts for the clamps , this will keep them from doing that again , ...... Hope that helped ..... if I got the bolts ou were trying to remove wrong , then try to explain in a bit more detail , or post a pic so I can see what exact bolt you are referring to ....
