Since its a 250L , that does create some issues with the fork springs , The shock rate you will need is a 12.5.kg , for your weight , (198.lbs/90.kg) but the fork will require a 0.57 for your weight , and they are not available from Race Tech ..... however , that does not mean you cannot use another manufacturer's spring for the forks , like Factory Connection , or Eibach , etc. , to see if they have that rate , you could call Race Tech directly and see if they can make up for the spring rate difference with a valving and oil setup that would make the bike work with a lighter (made for a 180.lbs/81.6kg rider) spring , which is the stiffest they offer , and either you or the guy you choose to redo the valving can set it up to their recommendations possibly making the compression stack stiffer to accomodate for the extra weight , the reason I believe it may be done with valving , is because you will unlikely be jumping with the bike , so the adjustment would be to ensure proper handling and front to rear balance rather than for bottoming resistance ... follow ??
So give Race Tech a call first , and see if they can give you some direction for the front spring issue , 1-951-279-6655 (not sure about international dialing) , as I think that will be your only hurdle , once you can either locate a spring , or get a valving stack and oil level that will make up for a lighter spring (you will need to replace your stock springs front and rear due to your weight and the stock spring weight limit) ....
Sorry i could not be of more help , but with a 250R or X you have many more spring options than for the 250L because of the smaller diameter , less adjustable fork they have , so not a lot can be done , but to either try to find the rate I posted , or locate someone who might stock one , or at worst , have springs custom wound ..... Or try to get the valving to make up for it somewhat , which Race Tech can help you with , Basically , if you can keep the bike up in the stroke and not diving into corners and not putting all the weight on the rear wheel while exiting corners where you would also lose steering , I think you will be OK with a lighter rate , as long as a stiffer compression valving setup can keep you in the top part of the stroke longer , and a slower Rebound setup will keep the front from wheeling out of every corner , then in the mid compression stroke can become plusher so the bike transitions into the corner without diving into it making the bike sketchy , I think without needing to worry about what the bike would do jumping , you will be fine ..... Also since you are basically doing a SuperMoto setup , I believe the suspension will have some limiters in it , which will help somewhat as well , as there will be a shorter stroke , so the bike may not be as tippy front to rear as a fully suspended bike would ....... this is all depending on if limiters will be installed of course ...
