CRF250L rear Shock Spring help
  • Because
    by Because » Mon May 25, 2015 6:55 am
    I am thinking about changing my rear spring for a better ride. I don't really know where to start and figured someone has already figured out what was the best setup.
    The CRF250L is stock. I am 190 pounds and just do Forest roads and dirt roads and very little off road.
    I do not know what the stock spring rate is or what spring rate I need?
    Here is what I would like to know:
    What is the stock Spring rate?
    What spring rate do I need at 190 pounds?
    Where do I need to order the Spring?
    Add any comments.
    Thanks,
    because
    by JimDirt » Mon May 25, 2015 9:18 am
    Welcome to the site ! \:D/
    Stock Spring Rate is (forks).72kg (shock)9.5kg
    For your weight you should be (forks)0.428 (shock) 11.232
    You can get your springs direct from Race Tech (where i got the spring rates from)
    http://racetech.com/ProductSearch/1/Honda/CRF250L/2013
