450X/250X suspension components interchangeable???
  • billygoatgruff
    by billygoatgruff » Thu Apr 11, 2013 4:16 pm
    So, my question is will the forks and rear shock from an 05 450X swap over to an 07 250X?
    450x's suspension has been custom tuned/valved
    Thanks,BGG[/b]
    by crfsonly » Thu Apr 11, 2013 9:51 pm
    yes...i believe they will. the only issue might be the shock bearings and i haven't cross referenced them to verify but that would a fairly easy fix if it were the case.
  • billygoatgruff
    by billygoatgruff » Fri Apr 12, 2013 2:50 pm
    Thanks, Ken
    Is there any special valving for the weight difference between the 2 bikes?
    On a side note. This 450x has a scott's sub mount w/dampener that I could also get. Will the bar/stabilizer mount work on my 07 250x and then I could buy the post for the 250x?
    Thanks,BGG
    by crfsonly » Fri Apr 12, 2013 4:19 pm
    Yes, the valving will be different but not much. Better to have them valved and sprung specifically for your weight and riding. On the SUB/Scotts. The SUB mount will work but you'll need a new bolt on post tower. The frames are different. We offer this is you need a source for one.
    Ken
