front forks
  • dvorak1
    front forks
    by dvorak1 » Sun Jun 17, 2012 8:19 am
    just got done riding my 450r after jumping the landing is preety hard and it wants to jump back both top and bottom are set in the middle any suggestions
    by crfsonly » Sun Jun 17, 2012 4:26 pm
    if i understand you correctly you need to adjust your rebound. of course before anything you need to make sure you have the correct spring rate for your riding weight. otherwise, the compression and rebound adjustments won't provide the designed adjustability you need.
