Rear Wheel Dancing Through whooops?
    no teeth no problem
    by no teeth no problem » Fri Apr 13, 2012 11:24 am
    I ride fairly aggressive when trail riding and i notice when going through whoop sections for a long distance by rear wheel tends to go from side to side and occasionally sending me to a tank slapper.
    Would I need to soften my suspension or make it more stiff? Or just change the response?
    Any ideas?
    shake and bake
  • Dasquriel
    by Dasquriel » Fri Apr 13, 2012 3:39 pm
    Could be your riding postion lean back and pinch tight with your knees unless it sand whoops or loamy then stay neutral position over the bike. Then u could try valving of suspension then u could try shortening shock shaft if none of that works then lastly try a lowering link
  • 357Warrior
    by 357Warrior » Fri Apr 13, 2012 5:52 pm
    check your sag also
    "If you think it's impossible, it's possible you're not thinking"
    mxracer76
    by mxracer76 » Fri Apr 13, 2012 6:53 pm
    You could also try changing your rebound settings. It might be to slow and your shock might be packing up.
    redrider250r
    by redrider250r » Fri Apr 13, 2012 7:37 pm
    mxracer76 wrote:You could also try changing your rebound settings. It might be to slow and your shock might be packing up.
    I ride motocross and I had the same problem. I bumped up my rebound 4 clicks in the rear and it fixed the problem.
    "If you don't crash, you ain't goin fast enough"
    "The faster you go, the smoother it gets. (Unless saying #1 comes into play)
    2009 CRF250R (mine)
    09 CRF250R (brothers)
    08 CRF250X (dad)
    kicken
    by kicken » Sat Apr 14, 2012 8:56 am
    Yeah ... if you're hitting them fast, then up the rebound, otherwise the shock doesn't recover fast enough between each woop.
    '06 CRF450x
    no teeth no problem
    by no teeth no problem » Sun Apr 15, 2012 3:42 pm
    sped up the rebound and it rides through like butter now tweeked it back and forth until i found my sweet spot. Thanks guys
    shake and bake
