Setting Race sag
  • 28Andy
    Setting Race sag
    by 28Andy » Sat Aug 27, 2011 6:36 pm
    i recently set my sag and i dont know if i need change the stiffness or softness of my forks to make things even.
    by crfsonly » Sat Aug 27, 2011 8:44 pm
    welcome Andy to CRF's Only. the sag sets the proper pre-load on the shock spring. so, i your weight is such that you were able to do this with the spring you have you likely do not need to adjust the fork spring rate.
  • 28Andy
    by 28Andy » Sat Aug 27, 2011 9:00 pm
    crfsonly wrote:welcome Andy to CRF's Only. the sag sets the proper pre-load on the shock spring. so, i your weight is such that you were able to do this with the spring you have you likely do not need to adjust the fork spring rate.
    s
    So should i just leave my forks the way they are?
