Set up - Shock Perload Collar Tool - Spring rate Q's
Posted: Sat Aug 30, 2008 7:11 pm
Kinda new to tuning dirk bikes. Never really touched my last bike. I never really tried to push on it (it was my first bike KTM EXC 250f, this is my second year riding). So I never really felt the need, I was comfortable on it. Never really road MX tracks much either. Now that I am on my new bike it is wacked feeling. I am afraid to jump it, it seems unpredictable. Oh its a 06' CRF450.
I played with the "clickers" a bunch today and got things to settle down quite a bit. 5 clicks less LS, 3 clicks less HS and 3 more rebound. I was getting kicked and swapping the rear end around. Mostly under acceleration, jumping. But now the bike feels almost too dead at times. Mostly while breaking / cornering in choppy stuff. Maby it is packing up? Can you mess with the psi in the shock? If so what traits will that effect?
May one just take a punch and hammer to loosen off shock collar top ring. Then adjust the bottom one. Taking into consideration the risk of slipping with the punch and smoking the threads (I think I will be fine). Or should I go get a collar spanner, if so what one would you recommend. I think I will be using this tool only a few times. Once to see if I can get the sag / feel right with the stock spring. Maby again if I need to swap to a lighter spring.
Bringing me to my second question, I am about 150lbs with out gear so maby 165 with. What spring would you guys recommend? Beginner motocross with some trail riding / racing.
Leading me to the fork, I really feel like it needs softer springs. Backed the comp off a bunch after playing with the shock. To try to balance things out, it still feels bit harsh. I have no idea what the oil level is at, I have yet to go there. I did put some air bleeders on and use them. They seem to help a bit.
I think once I get the rear end sorted I will drop the forks in the crown to get it to turn in better. But I wouldn't do that now as I get the occasional, mild head shake as it is.
Maby I am barking up the wrong tree here, trying to get the bike to feel softer, like my old KTM EXC trail bike. Or like my Down hill bike. Maby I need a new mind set, approach. I don't have a bunch cash to toss at a tuner. I like to sort things out for my self. Its more fun that way. If I can't get it much better by winter, then I will go down that road. Also I am not afraid to tear down the fork. I did my KTMs with out any worries. I haven't got into playing with shims or any like that yet. Just a simple oil / seal change. But Iam willing to try if some one has a killer set up.
Thanks for help,
Tom
Thanks for help,
Tom
