Rear end bottoming
    RedRider#4
    Rear end bottoming
    by RedRider#4 » Wed Feb 06, 2008 11:21 am
    I have stock shock, race sag set at 100 mm, free sag 29 mm, with this set up on the rear when clearing a local table top my rear shock is bottoming out, rear wheel rubbing inside of fender. Anyone know how to cure this problem? I have factory standard clicker positions on the shocks rebound and comp.
    Keep it PINNED.........Barp!
    CRF250X 06
    Airbox mod
    Filter mod
    JD Kit mod
    Hotcam S1 mod
    AP mod
    Pink mod
  • redrooster65
    by redrooster65 » Wed Feb 06, 2008 12:25 pm
    re spring it for your weight and style of riding
  • rocketman
    by rocketman » Wed Feb 06, 2008 12:35 pm
    Call factory connection and talk to their tech guys. They will tell you what springs you should have or send them your stuff and they will set up.
    http://factoryconnection.com/
    Springs are all available here on the crfsonly web site.
    Bryce
    by Bryce » Wed Feb 06, 2008 8:00 pm
    are you noticing a clunk when it hits bottom???? if your not don't worry. the tire rubbing the fender isn't a big issue, but that hard slam is. also is it possible your not actually clearing it but hitting the the top of the landing with the rear wheel? I find the need for stiffer suspension more needed in wooped out stuff more than correctly landing jumps (which I suck at).
    Bryce
    marks crf
    by marks crf » Sat Jun 07, 2008 7:47 pm
    adjust the rebound clicker and make it slow down when u land so it doesn't bottom out so quick
    i done this to my crf250r and it doesn't bottom only if i over clear a jump say 4 meters and land flat bang smack :D :D :D :D it doesn't feel good to bottom out :oops: :oops:
    by Skoot22 » Sat Jun 07, 2008 8:11 pm
    Turn up the low speed compression a couple clicks.
    How much do you weigh?
    Here is a good suspension artical
    http://www.motocrossactionmag.com/me2/d ... 9FFEA106BF
    Riley
    by Riley » Sun Jun 08, 2008 9:31 am
    Skoot, good link! Thanks! I'm having issues dialing in my suspension to ride smooth. Don't hit a lot of jumps, generally nothing higher or harder than a good wheelie or 3' drop offs.
    Tombo
    by Tombo » Sat Aug 30, 2008 7:20 pm
    marks crf wrote:adjust the rebound clicker and make it slow down when u land so it doesn't bottom out so quick
    I do believe that rebound will not effect bottoming. As it controls the return stroke, not the compression. Then only time it would effect the compression is, that if it is set too slow and "packs up". Meaning the it doesn't have time to move back up the stroke in time for the next hit. This is only in choppy stuff.
