BEFORE YOU PUT THEM ON THE BIKE !
Make sure when you assemble everything , to check the TOTAL amount of clicks for each rebound clicker , they both should be what it says in the manual , and both be the exact same , if they are not , then you must (with the forks upside down) loosen the rebound assembly hold it under the nut with the tool and adjust the nut accordingly , its fairly sensitive to adjustment , so 1/4 turn will be noticeable
The manual tells you what the measurement should be when setting the rebound nut
So when checking , if it clicks a TOTAL of 16-1/4 , and the other clicks 16 (this is till it totally stops , without forcing it , and the total movement , so if after getting to the last click it moves a 1/4 the way to the next click , then that is what both forks should have for a setting ...follow ??) , then you need to adjust the one that is only 16 so it matches the other fork , otherwise , the forks will be slightly different length , and what will happen is when you set your axle (you do set your axle before throwing the tire on right ??), you will have 1 fork higher or lower in the clamps than the other , so this is important to avoid fork bind , and something a lot of people fail to check
The axle should slide (when both fork tubes are exactly equal in the clamps) in easily , without lifting or forcing it thru both sides with no effort , if it hits the other side, and has to lift or drop slightly or you have to slightly compress or pull on the fork tube to get the axle thru , then 1 of the forks is a different length , if it does not align , and the forks are at the same height in the clamps , then remove the one that is shorter , and reset the nut on the rebound , making sure both are equal in clicks
You are still on the lighter springs correct ??
Keep a eye on what your "normal" travel is to see where its sitting , and take note of your clicker settings , , if your having to go almost all the way stiff and the forks are consistently lower in the stroke , then you will need the stiffer springs
mossman77 wrote:BEFORE YOU PUT THEM ON THE BIKE !
clicks
I understand. Manual says to use loctite on the rebound nut threads. Should I use high strength (Red) or medium strength (blue)? Also, one of the compression clickers turns about 1/4 turn (1/2 of a click) past it's full soft setting, whereas the compression clicker on the other fork stops at the last click. Is there a way to adjust the compression clicker so that it doesn't have that extra 1/4 turn after the last click? Does it make a difference either way?
YesKeep a eye on what your "normal" travel is to see where its sitting , and take note of your clicker settings , , if your having to go almost all the way stiff and the forks are consistently lower in the stroke , then you will need the stiffer springs
I'm going to use the zip tie method you recommended. Does the same rule apply to the front sag as to the rear? If when I sit on the bike, the front compresses more than 1/3 of the full travel, then I need a stiffer spring (or more preload) right?
As far as the clicker being off from the other , its similar to the Rebound settings i mentioned , what that means is that in the compression cap assembly (Fork Cap Assembly) , the lock nut and top cap have been adjusted differently than the other side , this could be from manufacturing not being accurate/matched pairs , or it could have been taken apart at some point in its life and not measured/checked with the other side to make sure the clickers match , the adjustment is done in the same way , but the cap assembly locknut is loosened , then a holding tool to hold the Low Speed Valve is used while you turn in the 32mm nut at the top (the long skinny looking nut where the comp clicker is) , takes a 32mm 6 point socket , and moved slightly, then checked again to see if its the same as the other side , then tighten the locknut , then check again to make sure
Again , this must be done with the assembly out of the cartridge , but it does not have the same effect as the rebound does as far as fork overall length from it being different , BUT , if the one does not click the same amount as the other (16 clicks or whatever the actual number) , then yes that would be a issue and it would need to be taken apart and adjusted
mossman77 wrote:Looking ahead...should I rebuild the rear shock as well? The bike doesn't have a whole lot of hours on it, but it is 8 years old. There's a really good YouTube instructional video on how to (https://www.youtube.com/watch?v=WiP2_AHViLs) so I'm confident I can do it. I would just need to take it somewhere to get it filled with nitrogen when I'm done. If recommended, what parts should I replace? Is this a good kit?: http://www.pivotworks.com/ProductInfo.aspx?item_id=1797
I meant what he charges for the aftermarket parts
, but your list is fine , don't forget Shock fluid , i prefer it to fork oil , its lighter and made specifically for shocks , its less foaming than fork oil
