No problem , and it will look intimidating at first , but once you do it you will wonder why you never tried doing it sooner , even the shock is fairly straight forward , the only issue with it is recharging the Nitrogen , i ended up biting the bullet and got my own bottle and gauges (about $250) , but now i dont have to worry about finding a shop open when i want to take apart the shock then recharge it , and when i change oil in the forks i can now do the shock at the same time , and you only need a few specialty tools for the most part , the bottle being 1 of them
but if i cant walk you thru things ,(which i usually can for assembly or technical issues and such) then theDogger definitely can , he can pretty much tell you what shims to run and where in the stack to put them , the guy needs to open a shop , because he knows more than most anyone in suspension i have dealt with , especially since he does not do this for a business , that just amazes me (you talk to him on the phone and it dumbfounds you at the knowledge he has amassed in such a short time doing this stuff)
