Loudmouth Filter System
  • VetJunior
    by VetJunior » Fri Oct 09, 2009 4:47 pm
    Yeah I know I will probably catch flack for spending as much as I did for the system but I figured I would post anyway. I'm a bit OCD when it comes to my bike. That means I pretty well disassemble and clean every time I am back from the races. I became rather sick of the filter changes on my 08 CRF450R and finally purchased the Loudmouth system. Let it be known I only bought the system based on the ease of filter changes and airbox cleaning. The system is great, easy installation, and the filters are pretty well idiot proof. As expected there has been 0% increase in performance. It's a very pricey system for what it does, however, this system combined with the No-Toil filter oil is in my opinion AWESOME.
    So for those of you who are on the fence. Don't waste your hard earned cash if you think this system will make your bike faster because it won't. What it will do is make the undesirable task of filter changes very easy and CLEAN.
    by [email protected] » Sat Oct 10, 2009 5:06 am
    Hey,
    From what I've seen that system is pretty sweet.
    Anything that makes filter maintenance THAT easy on 02-08 CRF's looks like a winner to me.
    I should get that set-up for my project 08 450R. Doug
  • VetJunior
    by VetJunior » Sat Oct 31, 2009 6:25 pm
    Yeah I certainly appreciate having that system on there. One thing I forgot to mention when Installing. Some of the kits come with what they call a "neo-seal". In my opinion, the "neo-seal" should be removed from the kit and kindly set off to the side of your workbench far from reach. I was curious to know if the problems I had anticipated would actually crop up. They did.
    First and foremost the very thin retainer plate that rests on the back of the boot is, as I said, very thin. The gasket they provide is approximately 1/8" thick and will be sandwiched between the Loudmouth intake and the air boot; both of which are very smooth surfaces. You see where I am going here? After my initial test install I was pretty bummed out to see that the gasket was beginning to squish out from between the two surfaces.This began to happen prior to having the mounting bolts anywhere near tight enough to what may have provided a working seal between the parts. My other opinion on this is without the gasket, there is only one possible entry point for debris to get by, the single seal between the airboot and the loudmouth intake. With the gasket installed you now have two seal points that may or may not seal adequately.
    Anyway, to end a rather long and boring post I will sum it up. Set the gasket aside, apply a reasonable layer of Three Bond/Honda Bond/Yamabond or something similar to both surfaces to be sealed (loudmouth intake and airboot. Let it sit for a minute or so and then place them together. Insert the supplied bolts and lock nuts and tighten them up. Don't go crazy because that thin sealing ring will begin to deform if you go overboard. Personally I went and got a piece of 3mm plate aluminum, traced out the pattern of that wimpy sealing ring and cut to fit. Looks almost factory and allows a greater torque spec for an even better seal. A bit overkill I'm sure, but my OCD was kicking in.
    by crfsonly » Sat Apr 03, 2010 9:55 am
    I have added the Loud Mouth MX products to our catalog. We'll have them in stock on 4/9.
    Here's a link to them:
    http://www.crfsonly.com/catalog/advance ... loud+mouth
    NOTE: The EFI CRF models will be available soon and we'll stock those once they are available.
    Ken
    deejuks2
    by deejuks2 » Sat Apr 03, 2010 2:17 pm
    i bought the loudmouth system this time last year. So far it's the best thing i've added to my 450. I love that you can hear the air getting sucked in under your butt!
    by Old Dude » Sat Apr 03, 2010 7:03 pm
    Ken,
    4/9....Hmmmm, Can I order it now for my 250 and have you ship me the first one that you get?
    by crfsonly » Sat Apr 03, 2010 7:24 pm
    Old Dude...absolutely you can order it now. We'll hold the order until they arrive. Orders will be shipped in the order they are received just in case our initial order is insufficient to cover demand.
    Ken
