Fuel Screw brass seat?
    Scheky
    by Scheky » Mon Jan 25, 2021 3:08 pm
    My bike has been apart a while. Gunked up green ethanol in the carb. Cleaned before I moved. I remember dropping some parts on the floor. I thought I picked them up, but when cleaning the floor I found this small brass seat? The spring O ring and washer are gone.
    I ordered the fuel screw parts kit and some spare jets.
    Take a look at the picture. This looks like it might fit up in the carb. It doesn't fit in straight away, but if it belonged there I could probably freeze it. Just kinda weird. It does slide over the fuel screw.
    I was just hoping to get some feedback before I try to put it together. Thank you.
    05 450X
    Applied Block off kit
    Applied vent kit
    Factory R & D Fuel screw
    WC Skid Plate, Jet Kit,
    Air box Mod, 170, 11/4, Tugger
    R pipe
    Re: Fuel Screw brass seat?
    by Back2-2 » Mon Jan 25, 2021 4:16 pm
    Off hand I do not recognize the brass part - but it is not part of your fuel screw assembly. The only thing that goes on or in the fuel adjustment screw port is the spring, o-ring, and a washer between the spring & o-ring is a small flat washer. No brass shoulder spacer.
    by Back2-2 » Wed Jan 27, 2021 1:11 pm
    Thinking about it - could that brass piece be the needle holder?
    by Aussiecrf230 » Wed Jan 27, 2021 1:15 pm
    Could it be part of an anti tamper plug that has been drilled out.
    I initially thought a brass rivet.
    by Back2-2 » Wed Jan 27, 2021 5:07 pm
    Hey Ray,
    The anti-tamper plugs are usually aluminum plugs. That looks like to clean of a hole to have been drilled out.
    We need to set up a best guess wins ------ wait for it ------- Jim's old bike.... =DD
  • LeslieDoM
    by LeslieDoM » Thu Sep 16, 2021 1:22 am
    Anyone know who makes an extended fuel and/or idle adjustment screw for the 38 mm PWK? Id like to be able to adjust both without tools.
    If I cant find them Ill probably modify the stockers.
    Thanks
    Вывод сайтов в топ поисковых систем. Уникальные технологии по продвижению сайтов с выводом в топ поисковиков https://seo-runs.ru
