Cam similar to '02 R but for '08+?
Posted: Mon Dec 30, 2019 2:23 pm
by matt2491
Does anyone know of a super strong cam similar to the '02 R cam but for '08-up motors (updated decompression system)? I know I can swap in the older decomp parts but wanted to first get a lay of the land.
For context, I'm building a road race bike using a '14 CRF450X motor. Looking to build max power within reason, especially towards the top end.
Re: Cam similar to '02 R but for '08+?
Posted: Mon Dec 30, 2019 6:03 pm
by Leardriver
I hated the '02 cam, and put an '07 cam in my '08. It was fine for desert racing. But, for road racing, maybe you will like the '02.
Posted: Mon Dec 30, 2019 10:45 pm
by matt2491
Does anyone know what the characteristics of the '08 R cam are? How does it compare to the '02?
Since it is plug and play in '08-up X motors, maybe that's one to consider...
Posted: Mon Dec 30, 2019 11:13 pm
Not sure of all the profiles , but here is a somewhat list , hopefully it helps some , not sure on the 08 specifics ... :cry:
It is from this topic : viewtopic.php?t=23904
Honda Cams
Honda 2004-2005 HRC Cam - Part # 14110-NLZ-650
Really strong to top end cam, with a decent mid range, but lacks bottom end.
Intake Lift(inches): .390
Exhaust Lift(inches): .350
Intake Lobe Center (degrees): 110
Exhaust Lobe Center (degrees): 105
Intake Duration (degrees at .040"): 260
Exhaust Duration (degrees at .040"): 260
Honda 2002 CRF450R Cam - Part # 14110-MEB-670
A good all around cam, strong bottom and really strong mid range with a excellent top end as well.
Intake Lift(inches): .380"
Exhaust Lift(inches): .356"
Intake Lobe Center (degrees): 106.5
Exhaust Lobe Center (degrees): 107
Intake Duration (degrees at .040"): 249
Exhaust Duration (degrees at .040"): 272
Honda 2003 CRF450R Cam - Part # 14110-MEB-770
A good strong bottom and mid range cam. Slightly detuned from the 2002 R cam.
Exhaust Lift(inches): .336"
Intake Lobe Center (degrees): 109
Exhaust Lobe Center (degrees): 109
Exhaust Duration (degrees at .040"): 262
Honda 2006-07 HRC & Honda 2004,2005,2006 CRF450R Cam - Part # 14110-NLZ-610 & 14110-MEN-670
Really strong bottom with a decent mid range.
Intake Lift(inches): .374"
Exhaust Lift(inches): .313"
Intake Lobe Center (degrees): 107
Exhaust Lobe Center (degrees): 110
Intake Duration (degrees at .040"): 248
Exhaust Duration (degrees at .040"): 268
HotCams
HotCams Stage 1 - Part #1016-1
Decent bottom end and midrange increase. Signs off early.
Intake lift (inches): .378"
Exhaust lift (inches): .343"
Intake lobe center (degrees): 106.5
Exhaust lobe center (degrees): 103.5
Intake duration (degrees at 1mm): 237.5
Exhaust duration (degrees at 1mm): 268.5
HotCams Stage 2 - Part #1024-2
Good midrange and top end increase, good all-around cam. Lacks bottom.
Intake lift (inches): .402"
Intake duration (degrees at 1mm): 248
HotCams Stage 3 - Part # 1056-3
More top-end power than Stage 2. Will work well for TT and big bore/strokers.
Intake lift (inches): .409"
Exhaust lift (inches): .356"
Intake lobe center (degrees): 116
Exhaust lobe center (degrees): 104.5
Intake duration (degrees at 1mm): 251.5
Exhaust duration (degrees at 1mm): 265
