Larger rear sprocket- chain guide binding
  • PW80Dad
    by PW80Dad » Thu Jul 04, 2019 11:40 am
    I put a 54t (might be a 53 cant remember right now) on the rear and now the lower rear sprocket chain guide is binding a little
    It doesn’t appear to have any adjustment but I suspect the geometry has changed enough to cause the bind. It occurs right as the chain exits closest to the sprocket
    Ami I being anal or should I do something? I’ve ridden it around the yard and it hasn’t torn itself apart yet lol. (It’s a tractor now with the 12t in front )
    Appreciate the input
    Re: Larger rear sprocket- chain guide binding
    by JimDirt » Thu Jul 04, 2019 1:50 pm
    I am assuming you replaced the chain with a longer one and have the wheel moved back ???
  • PW80Dad
    by PW80Dad » Thu Jul 04, 2019 3:52 pm
    Yes new longer chain. I guess I could run the chain a little tight to see if that helps
    by JimDirt » Thu Jul 04, 2019 8:14 pm
    With the 53 or 54 you want the wheel as far back as you can get it to keep it out of the guide , but , it still should not physically harm anything as is .............
