Thanks, been lurking here for a while but haven't needed to ask anything before now.Welcome to the site !!
Sorry , just noticed this post
Battery grounds to the engine just next to the clutch actuator
From what I've read the stator won't have enough power to charge the battery if running lights off it too. I don't really want to kill a new lithium battery. They have a separate lighting circuit for the headlight.Why not take the power feed off the battery via a fuse of course. Isn't this how the X is already wired or is it a dedicated lighting circuit with seperate lighting coil in the stator?
The U.S. bikes are 12v at the bulb , the Aus bikes are not ??? , confused , if the LED is 12v and the Watts are within spec then it should just be straight hookup as far as i know
The U.S. models are 12v DC at the bulb , thats why i said if the watts and voltage is the same then it should just be a plug in and go , anything that would be AC voltage would be converted in the Regulator , but as far as my Factory Honda Service Manual says , all output voltage from the Stator is 12v DCFrom what I've read the stator won't have enough power to charge the battery if running lights off it too. I don't really want to kill a new lithium battery. They have a separate lighting circuit for the headlight.Why not take the power feed off the battery via a fuse of course. Isn't this how the X is already wired or is it a dedicated lighting circuit with seperate lighting coil in the stator?
12V AC? from looking at the wiring diagram it would be unregulated ac at the globe. Led's need dc and close to 12v with not much variance. US and Aus wiring should be the same.
This is the diagram i've been using for everything else and so far its right.
