Engine help !!!
  • icepilot
    Engine help !!!
    by icepilot » Sat Jan 31, 2015 10:26 am
    OK long story short somehow after i disasembled the top end of my engine. Things got moved (Crank turned) and the cam chain has become wraped up in its drive gear. I am not able to turn the engine in the opsite direction of rotation? is this normal and dose anyone have any ideas how to get it undone ? [/img]
    by JimDirt » Sat Jan 31, 2015 11:31 am
    Your image wont show up unless you use a hosting site like Image Shack , etc
    What i am guessing is the chain has become stuck at the guard that prevents the chain from coming off the crank gear , if it wont pull back up (it should , but) ,then you will have to remove the ignition cover (this is assuming that you have already removed the Chain Tensioner and it still would not come out) , and try to get behind the flywheel to dislodge it with a screwdriver or similar slim tool , while tugging on the chain from top , if you have a flywheel puller (specifically for the X) , then pull the flywheel so you can easily dislodge it , but most likely its draped over the guard that keeps the chain on the crank gear and stuck there , and that is why its not lifting
    What you "should" have done was wire the chain up on the frame after removing the head and/or cylinder , then pass the wire thru each as its assembled , this way there is always tension on the chain holding it up till your ready to put it over the cam gear
    Oh !! , Welcome to the site !! \:D/
Users browsing this forum: Google [Bot] and 8 guests
