JimDirt wrote:What is your elevation (or the elevation you normally ride)
This is the guide for jetting
Jetting Guide for Main Jet:(pilot 45)CRF450R/X
Sea level...165
2000 ft.......162
4000 ft.......160
6000 ft.......158
8000 ft.......155
Temperature/Elevation:
JimDirt wrote:Bottom of the carb at the front of the bowl
You need one of these , it will make life easier so you dont have to loosen the carb and twist it sideways to adjust the fuel mixture
http://www.crfsonly.com/catalog/product ... ts_id/2792
JimDirt wrote:I have a question , are you oiling the crap out of that No-Toil filter ?? , if you are your starving it for air and that would make it bog,pop,stall
With a #45 pilot and a main in the area of 160 - 165 and the fuel screw between 1 1/4 - 2 3/4 , the bike should run fine
Rule out that the squirt is not hitting the slide when blipping the throttle (engine off , airbox off/ subframe up) and look to see down the throat of the carb if it just barely misses the slide , if the stream hits you need to adjust the AP timing , also try taking a small O-Ring and putting it around the AP screw and the stop
I thought there was a post here , but this is the only one i could find that has pictures to show you what to do , but this might help stop the bog
Also , if your rev-ving it on the stand it will bog /pop/stall sometimes , so make sure it runs fine under load , on the stand means nothing (sorry Ken for the link to that "other" site)
http://www.thumpertalk.com/topic/539540 ... or-an-fcr/
