No more keyed Barrel. Just a 'Go" button?
  • Matts450x
    by Matts450x » Mon Sep 02, 2013 9:51 am
    Hi all,
    Once again thanks heaps for helping me out with questions that i have.
    I am a newcomer to the site and the amount of information contained on here and the expertise is amazing.
    I am going to go with some brp Triple clamps (not sure about 22mm or 20mm yet but thats another topic)
    which will mean i don't need the key barrel mounted on the front.
    Are there any good aftermarket options where i can just re-wire a starter button on the bars and lose the keyed barrel or does this create problems?
    I am losing the front light and just going to a number plate so the light won't be drawing power from the battery constantly?
    The 450x is sensational btw.
    Best bike i have ever ridden.
    Dialing it in to my height and weight now to make it even better.
    :D :D :D
    crazybrother
    by crazybrother » Mon Sep 02, 2013 5:36 pm
    Where are you located? All the U.S. models don't come with a Key switch, they have a start button that's next to the throttle with a switch that operates when the clutch is pulled in. However I have added a Key switch to mine for security purposes from Baja Designs... If yours is a aftermarket switch then i'm sure it can be bypassed. But if it's an OEM switch then I would check your wiring diagram from where you live.
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
