by Kiwi » Tue Jun 11, 2013 2:37 pm
While removing the factory smog stuff may help, I don't think that it is the real problem.
I have a 2007 CRF450X with modified airbox, Uni filter w/no backfire screen, NCVS needle on 4th, 172 main, CRFs fuel screw at 2, Boyesen QS3, 450R cam, FMF Megabomb header, and Pro Circuit T-4 muffler. I still have the factory smog stuff on and the 450X runs awesome with no backfire pops, throttle tip-in hesitation or such.
I think the real problem is:
1. Your 450X is way too lean. The 148 main jet needs to be upped to a 160 or 165 (depending on engine mods, altitude, etc.).
2. What needle are you running (stock??) and at what clip height? For about $15.00 you can get a NCVS needle (16233-MEN-671) from the Honda dealer that will perform much better than the stock needle. Set the clip height to the 4th and you should be ready to rip. [Be sure to adjust the fuel screw after jetting. Approximately 1.5 - 2.0 turns out will be required]
2007 CRF450X with modified airbox, Uni filter w/no backfire screen, NCVS needle on 4th, 172 main, CRFs fuel screw at 2, Boyesen QS3, stock smog, 450R cam, FMF Megabomb header, Pro Circuit T-4 muffler, Pro Taper Evo bars, AS suspension
