Clutch issue.
  • fluffyalien
    Clutch issue.
    by fluffyalien » Sun May 19, 2013 7:53 pm
    Hi,
    I have a 2010 CRF450X with a Rekluse exp2.0 clutch.
    When riding at the weekend something happened and the lever came back to the bar. I checked the cable which is fine but found there is no tension on the clutch actuator arm. I haven't had time to pull off the clutch cover yet but i'm after a few ideas about what i should be looking for, what could the issue be?
    Any help and advice greatfully recieved
    cheers
    Jamie
  • Kap
    by Kap » Sun May 19, 2013 8:50 pm
    Get rid of that clutch lever all together, you don't need it anymore. Throw the clutch cable in the trash and put your rear hand brake up there.
    06 CRF450X Rekluse with hand brake.
    CR500AF Rekluse rear hand brake.
  • fluffyalien
    by fluffyalien » Sun May 19, 2013 9:04 pm
    Kap wrote:Get rid of that clutch lever all together, you don't need it anymore. Throw the clutch cable in the trash and put your rear hand brake up there.
    It's the Exp2.0 NOT the core EXP so unfortunately that won't solve my problem :-(
    Cheers
    Jamie
Users browsing this forum: No registered users and 12 guests
