Hi, I recently purchased a new 2012 450x. I ride in tiger stuff so I ordered a 52 teeth rear sprocket for the rear. I pulled up the gearing calculator here: http://crfsonly.com/howto/gearing/motor ... ulator.php
to check the differences compared to stock. This doesn't seem like it is going to lower the gears that much. Does it feel a lot lower adding one tooth? Also, does anyone know if I will be able to use the stock chain? Thanks.
