the ballast for a HID can be designed for either a DC or AC input. If your kit tests good on your trucks DC system then the ballast wont fire from an AC supply. Is that what the installation told you to do?Kyle450x wrote:So today I went about installing the HID kit. Although my halogen bulb worked great, when I plugged the + and - connections onto the stock wiring harness, the HID would not fire. After testing it on my truck, it all checked out good.
Kyle450x wrote: So now i'm just gunna wire it directly to my battery. Any insight there?
Kyle450x wrote: maybe an inline fuse too? What wattage fuse? 35?
gal8x wrote:Yes. You are pulling off the circuit that runs the bike. you need to pull from the other stator winding. Preferably before you need to order a new one.
gal8x wrote:gal8x wrote:Yes. You are pulling off the circuit that runs the bike. you need to pull from the other stator winding. Preferably before you need to order a new one.
I don’t like how this is worded so I am revising it.
What you have done is move the load (the energy that drives the light ) to the opposite side of the regulator than the circuit was designed for. If the OEM regulator can handle 48 watts ‘continuous’ duty then the circuit should hold. Personally I would install a 55 watt regulator, bigger is better as you know.
PPS. You cannot use the old headlight wiring. If you load that circuit you risk overtaxing the stator.
