Aussiecrf230 wrote:Ken,
Does that tank come with a spare set of heavier fork spring for when you fill it up.
How many usable litres/gallons?
No springs - it's really not that much heavier - 12lbs of extra gas and the tank weight is negligable... maybe 1 lb. Plus you get rid of the shrouds. Anyway, an extra 13-14lbs. I'm about 190 with my gear on, maybe 200 with the saddle bags full. I don't notice it but I'm probably not the best person to judge it.
Truth is, the reduced stress of running out of gas in the middle of colorado somewhere is worth its weights. Also, I usually road ride to the dirt ride so by the time I get there it's less a gallon maybe. Also, the gas is held really low in the shrouds. All in all, the tank fits great and works great. The fuel line routing makes it a bit more of a job to remove the tank, but not that bad. The extra two petcocks give you all kinds of options for extra reserves. Last, the mohard radiator guards fit perfectly with the tank - assuming you install them both correctly which took an extra attempt for me.
All in all, bike is running great. Lots of gas allows me to stop thinking about it so much!
