It looks like I have some work to do so I can crush the KTM
You'll be ready for the KTM ,no problem.You're going to be loving it.
If you do all of it,the jet kit,the fuel screw,the smog block off, it's not much money at all for the increase in performance you get.
Just do it all simultaneously, the jet kit,the smog block off, the air box mod. When you go on you rfirst ride when you're done you'l be all smiles.
The fuel screw wil make your life a lot easier, just make sure you get the spring,washer and o-ring off the original fuel screw and on the new one. Doug
