Dual sport conversion
    afc1261
    by afc1261 » Fri Dec 29, 2006 2:23 pm
    I went to the local inspection station to ask what they required to inspect my 450x so I can get a plate for it. They said the brake light has to function by not only the rear brake lever but also when the front brake lever is squeezed. Has anyone done this and can you tell me how you did it? I checked the crfsonly catalog, californiadualsport.com and bajadesigns but I can't find a switch for the front brake lever. Thanks.
  • HONDARACER
    by HONDARACER » Sat Dec 30, 2006 1:09 am
    Its a hydraulic switch that goes in the banjo bolt at the master cylinder. You should probably just buy a Baja designs kit and it comes with most everything you need. TIres and a chain gaurd are all I can recall needing extra to get mine street legal.
    I'm a Honda racer and I go real fast
    I got a cute bike and it really hauls azz
    If you see me on the trail, well you better stay back
    Cause I'm a Honda racer!
    2005 Honda CRF450 X
    STREET LEGAL NOW!!!!!
    SUPERMOTO NOW!!!!!!!!
    MarkB
    by MarkB » Sat Dec 30, 2006 6:52 am
    Use the entire BajaDesigns kit, you cannot go wrong. Mine works great, and I have the Plate!
    Mark
    2001 Kawasaki ZX12R 180HP Beast machine
    2001 Ducati 996SPS full blown crazed track bike
    2006 Ducati 999S street beast
    1983 Honda CT110 old faithful
    2005 Honda CRF450X, Dual Sport, stuffed with everything optional goodie I can buy.
    pgiinc
    by pgiinc » Sat Dec 30, 2006 8:40 am
    I have done two a 650R and my 450X your first mistake was asking questions to you inspector there. now if you go back you will have to have the front brake light work, Baja kit does not come with it . you can get one for the front brake. Just install the Baja kit first then find another place to have it inspected and don't say anything about front brake lever but yes I have mirror,horn, brake lights,signals,dot tires,hi low beam. take you inspection slip to DMV and get you tags
    afc1261
    by afc1261 » Sat Dec 30, 2006 4:37 pm
    pgiinc wrote: you can get one for the front brake.
    That's my question. Where can I get a switch for the front brake since it doesnt come with the baja designs kit? Is it the same switch as the rear hydraulic brake switch or is it different and can you direct me to who sells them? All the other bases I have covered. Thanks
  • cbutler
    by cbutler » Sat Dec 30, 2006 6:50 pm
    It is just a pressure switch KEN has them just connect them together
  • HONDARACER
    by HONDARACER » Sun Dec 31, 2006 1:15 pm
    My BAJA kit came with front and rear bajo bolts for brake lights. IT was designed for the 450X and everything worked perfectly.
    2005 Honda CRF450 X
    by Asmith » Sun Dec 31, 2006 1:29 pm
    Alfie,
    They are available from Baja Designs separately for $20.00.
Users browsing this forum: Google [Bot] and 4 guests
