Vapor vs Lynx?
  • rider_34
    Vapor vs Lynx?
    by rider_34 » Wed Dec 27, 2006 2:44 pm
    Looking to buy one or the other Vapor or Lynx. Suggestions? Do I need to buy the dashboard protetor to keep these things in place?
    Killaz
    by Killaz » Wed Dec 27, 2006 6:55 pm
    Here is a comparison chart which may help you out...
    http://trailtech.net/store/computer_comparison.html
    Also, can someone explain how the temperature and tach sensors hookup?
    '05 CRF450X
    '03 YZ250
    jtsurfs
    by jtsurfs » Wed Dec 27, 2006 7:06 pm
    The temp sensor for the water temp goes inline in the radiator hose, the air tem sensor is an ambient reading.
    I would recommend the vapor, but mostly because that is what I have. The protector is worth the money in my opinion. It keeps the computer mounted and I don't think it would be easy to break either.
  • wt018
    by wt018 » Wed Dec 27, 2006 7:10 pm
    i have the vapor and i think its great pretty useful the tach hookup just wraps around the spark plug wire seems cheap but works good. its nice to know what temp you motor is never relize how hot it can get sometimes
    05 crf450x twin air intake system,jd jet kit, 170 main, zip ty fuel screw, boyessen apc, fmf header and q2 muffler, rekluse cover, applied triple and pro-tapers,smog block off,unibikers
  • rider_34
    by rider_34 » Thu Dec 28, 2006 9:35 am
    Cool, thanks. Looks like Vapor is the way to go.
    HKE PUK
    by HKE PUK » Thu Dec 28, 2006 9:49 am
    I'd suggest the billet protector for mounting. (Mine's on the way -- Vapor has arrived).
    I spend some time installing all the wiring last night and after looking at the supplied plastic mounting hardware, the billet protector is the way to go for sure. Besides, I can't see a good place to mount the unit with the supplied plastic parts that would afford any protection in a wreck.
    Do a search to see just how neatly the billet protector bolts up and works.
    Good luck!
    PS - The Vapor has more functions (temp control), but he Lynx has features that may be desirable for racing, particularly HS and such.
  • rider_34
    by rider_34 » Thu Dec 28, 2006 11:46 am
    hkepuk wrote:I'd suggest the billet protector for mounting. (Mine's on the way -- Vapor has arrived).
    Good luck!
    Good info, thanks Puk. ---Ray
  • rkadair
    by rkadair » Thu Dec 28, 2006 7:21 pm
    wt018 wrote:i have the vapor and i think its great pretty useful the tach hookup just wraps around the spark plug wire seems cheap but works good. its nice to know what temp you motor is never relize how hot it can get sometimes
    I just put my red wire under the hot coil lead !
  • Lewisclarke
    by Lewisclarke » Thu Dec 28, 2006 8:46 pm
    Have you seen the Acewell products? This is from a triple Lynx owner.
    '04 250X=280X
    '05 450X
    '05.5 KTM 950
    230/100/70 Hondas
    Titan/XJ/Sube
    CORVA/Blue Ribbon C. member
    Cabelas Platinum
    Environmentalist
    Activist
  • rider_34
    by rider_34 » Fri Dec 29, 2006 5:58 am
    Lewisclarke wrote:Have you seen the Acewell products? This is from a triple Lynx owner.
    No, do you have a link for some info?
