by CRFMASTER14 » Sat Dec 16, 2006 12:37 pm
Check the following:
Fouled plug- What does the plug look like? If it is black and sooty, that would indicate a rich condition. If this is the case, check to assure that you did not over oil your filter.This will restrict alrflow, causing a rich mixture, which could lead to a fouled plug.
OR- Move your needle to the 4th position. If your filter was filthy before, a clean filter will let more air in, promoting a lean condition. Unless you are at quite a high altitude, I would recommend the needle in the 4th slot. On my bike, the 4th slot is good from 0-10,000 ft.
Try your fuel screw at 1-1/4 again.
I am not a "pro", this is based upon my experience FWIW. Hope it helps.
I just want to be free,to ride my machine, and not be hassled by the Man...
