nox11 wrote:where do I measure the float level on this carb? The pic in the manual is very difficult to be sure.
the pump does not spray a stream of fuel or any fuel for that matter like it's supposed to - im not sure why...
fuel line is clear and the fuel gets to the carb as it should - i'm not sure what goes on in the float bowl and with the pump
i cleaned and re-assembled as per the manual, but that does not help to trouble shoot if something goes wrong though...
You measure from the edge of the float itself , from the base of the carb body , so with the carb held 90 degrees with the intake side of the carb facing up , with the pin that holds the float up , tilt it slightly till the tab on the float just touches the needle pin but without it pushing in on the pin , the measurement i believe is 8mm , so from the bottom of the float (the end that would be closest to the bottom of the float bowl) to the flat base of the carb body where the gasket would be for the bowl is your measurement , if its out then bend the tab on the float where the holding pin goes thru is , and measure again and adjust until within spec
as far as no squirt , that is most likely the starting issue and why your bike will not start , it needs that squirt of fuel to start , you need to see if the small jet in the bottom of the bowl is clear , if you blow air thru it , it should blow out some fuel at the top edge of the bowl (where the O-Ring gasket sits) if this is clear , then i would bet the diaphragm for the accelerator pump is bad , replace that (make sure you install it correctly and with the push rod side facing the push rod)
Then fill the bowl with fuel (install the bowl and fill the carb while holding it level) , then work the throttle (where the cables attach) and watch the fuel , it should squirt once you get fuel flowing to it (work the throttle a few times till it squirts , then it should squirt every time you work the throttle), then when you first touch the throttle the fuel should just miss the slide , if it hits the slide there is a adjuster screw at the throttle that adjusts the accelerator pump rod gap , adjust that till the stream just clears the slide and your bike should start right up
